gm car rear end 12 bolt - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-26-2012, 07:29 PM
what is lowest gear u can put in gm 12 bolt for a car? k thanks
Old 08-27-2012, 07:18 AM
delawarebill's Avatar
rear gears
i'd look into "jeggs and sumitt" cat's and see what they offer. other then that i don't know...
Old 08-27-2012, 05:47 PM
prostreet6t9's Avatar
Differential/Driveline
How low do you need? 557 Ratio available.
Old 08-28-2012, 01:29 PM
vinniekq2's Avatar
6.14s are still available
10 bolt rear end prostreets10_355 Transmission - Rearend 3 02-25-2009 05:55 PM
Gm 12 bolt truck rear end vs. car rear end '54 Pontiac Transmission - Rearend 6 02-05-2009 05:17 PM
4x4 12 bolt rear end same as 2wd rear end??? Ed ke6bnl Transmission - Rearend 2 05-24-2008 02:25 PM
10 bolt to 14 bolt rear-end conversion in 96 1/2 ton chevy 4X4??? tommytempest Transmission - Rearend 14 05-09-2007 08:19 PM
Rear End - 5 bolt axle shafts into 6 bolt rear axle??? Blue Chevy Transmission - Rearend 0 06-07-2002 05:23 PM
