Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - GM column ?
Thread: GM column ?
Old 05-20-2011, 08:14 PM
ogre's Avatar
ogre ogre is offline
the 'Duracell Project'
if you buy an after market cruise control, chances are the OEM switch will not work.
rosta makes most of the after market cruise controls i believe.
they will supply you with a replacement arm that works with their cruise and fits in the multi-function switch (aka blinker/dimmer switch).
to remove the arm, push in hard, turn to disengage the lock and pull the arm out.
as far as the wiper/spray switch, i haven't figured out how to make it work...
my truck has an 89 astro column with all of the gm connections
i use everything but the wiper control
i also have a rosta cruise control, it is very nice
