GM column switch / universal wiper motor. - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-15-2011, 12:41 AM
staleg's Avatar
Last journal entry: Home made gear stick
I know this have been discussed before, but now I have found a wiring diagram.
Trouble is that this diagram is for a Lucan wiper motor with 4 cables and ground. My universal wiper motor only has 3 cables plus ground.
The wiper motor diagram is what followed my wiper motor. The other diagram is from Pete's Cobra Project page:
http://www.kdomus.com/petek/cobra/nav.htm
Any suggestions on how I adapt these diagrams together?
Old 11-15-2011, 01:43 AM
Joe G's Avatar
Registered user
Assuming all is correct on those two diagrams, I would suggest this:
Hope this helps....
Old 11-15-2011, 04:03 AM
staleg's Avatar
Very grateful. Thanks!
Old 11-16-2011, 06:42 AM
T-bucket23's Avatar
Wiki Edits: 26
Joe Gs diagram is correct. He changed the feed to the #30 terminal. The fuse in any circuit should be as close to the power source as possible. The less unfused wire the better.
Chet
Old 11-16-2011, 06:49 AM
staleg's Avatar
Wiring with a relay means 2 fuses on each circuit then, right?
Should I locate both those fuses in the fuse box under the dash?
Old 06-11-2012, 01:18 AM
staleg's Avatar
Hi, I know this is an old thread, but I'm about to wire mye car now, and have an addition question regarding the diagram:
How do I get an universal washer pump to be operated via the GM Lever?
The column is from a '90 Chevy Astro. Is the washer operated during one of the three wiper wires, too?
Old 06-11-2012, 02:23 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
The washer pump is not shown above. You might be able to find a wiring diagram or info where to look, here.
Old 06-11-2012, 07:01 AM
staleg's Avatar
I have heard something about violet wire to washer...?
If the washer has its own wire, that'll be simple, of course.
Old 08-26-2012, 10:37 AM
staleg's Avatar
I know it's an old thread, but I will make an update, since I cant get this to work.
Below is a photo of the GM wiper wires.
Very grateful for any suggestions...
I have wired it like the drawing of the 3-wire universal wiper motor earlier in the thread.
Convert Column Wiper Switch to Dash shad88 Electrical 14 08-04-2011 03:44 PM
Wiring A Universal Wiper Motor 27Tall T Electrical 5 07-05-2011 11:07 PM
Anyone Tried this Universal Wiper Switch, or can you recommend one? wavetrain75 Electrical 2 10-12-2009 08:30 PM
wiper motor or switch 68goat Electrical 1 04-24-2005 04:39 PM
wiper motor wiring - gm column -- HELP PLEASE!! gtofloyd Electrical 2 11-11-2003 11:10 PM
