Demon carburetor Free speech parts auctions.
Bid on used parts to help fight the frivolous lawsuit filed against us.
Click here for details.
Parts currently up for auction: Don Garlits engine emblem, Demon carburetor, aluminum Hemi head, 1947 Chevy engine + suspension + parts, '30-'31 Ford headlights, '33-'34 Ford window regulator, "Power Rods" billet air cleaner top.
Mopar performance heads
Hotrodders Bulletin Board > Tech Help > Transmission - Rearend
  #1
Old 02-25-2008, 09:40 AM
k.c. k.c. is offline
GM Corporate rear end
Any one know what this is or how strong it is? It is supposidly out of a '78 Trans-am and is an 8 3/4" 10 bolt. I thought 8.5" was the size, not 8 3/4". I'll be putting maybe 350-400 hp. thru it. Whatayathink?
Old 02-25-2008, 10:17 AM
troy norrad troy norrad is offline
RE: GM Corp rearend
Hi do you have a ID code on it, 8.5 not 8 3/4 l'm sure it is a locking rearend, here goes the codes(PS 2.41) (PT 2.56) (PW 3.08) (PX 2.73) (PP 3.23) they are the codes for 78 pontiac firebird,T/A's as far as HP, 350 should be fine but 400 you might want to go threw it to check it out TROY
Old 02-25-2008, 10:23 AM
re: GM Corporate rear end
Troy,
I have not seen the unit yet, but I will put new gears and bearings in it. Am I correct that it is 8.5"? Can it be 8 3/4"? I think it has 3.08:1 in it now. Can I put 3.42:1 gears in?
Thanks
Old 02-25-2008, 10:26 AM
RE: GM Corp rearend
if it is 8.5 you can't change them around with other 8.5, they didn't but a 8 3/4 in any of them cars! TROY
Old 02-25-2008, 11:21 AM
novajohnb's Avatar
novajohnb novajohnb is offline
A 78 T/A should have an 8.5" posi rear standard (a base firebird will have an 8.5" open rear standard.)
gear ratio is 2.56 to 3.42 (probably 3.08:1)
it will handle 350-400Hp no problem if it's in good shape.
if you have 3.08 gears, you can swap 3.42 gears in to the rear- both use "3 series" carrier, which is 2.73 up to (I think 3.73 or 3.9?)
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "GM Corporate rear end"
Rear End - what to do?? 73Caprice Transmission - Rearend 2 01-04-2008 09:28 AM
will a '69 Chevelle rear end fit into a '70 Chevelle? SMO'KUM UP Introduce Yourself 2 09-17-2007 07:15 AM
Narrowing a 9" ford rear end powerrodsmike Suspension - Brakes - Steering 6 05-05-2007 12:53 PM
What is the gear ratio for a GM rear end? jpd37 Transmission - Rearend 6 02-23-2004 12:52 PM
anyone running 700r4 with 3.55or 3.77 rear end? 37 chevy Transmission - Rearend 7 01-06-2003 06:34 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2008. All Rights Reserved.
