Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - GM courtesy lights
Old 09-16-2003, 12:10 AM
78 monte 78 monte is offline
E.T. divided by $ spent= Speed
Just got it done today.I put two under the dash,one on each side and a dome light,which is just hanging,cause theres no headliner yet.Got it all from the junkyard for $7.
I couldn't hook up the doorjams as there is no space to fit them.I didn't measure ahead and wound up putting one in and squashing it.Ooops.But its all off the dash switch which is still OK too.
I also ran a feed off the hot to the back two panel lights which have there own switches which ground to the body.So they are steady hot and controled by the little toggles that are on them.
