gm crate 350 overheating problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-30-2009, 05:52 PM
ok im sry i started a thread on your forum about my truck but i figured y'all could help me. i have a 1995 silverado. it a 1500 with 4x4 and 700r4 trans. i bought the truck with 193000 on it and decided to swap motors. i found a gm 350 crate motor and rebuilt it. i got it all in the truck and now when i start it up it will warm up to 220 to 230 degrees. i have a 160 degree thermostat in it. after it warms up it will cool of to 160 and run there forever or till you shut her down and the thermostat closes. i put a brand new radiator and water pump in when the motor went in. Ive also tried many, many thermostats but still have the same problem. oh and the reason why i run a 160 degree thermostat is so i can actually drive it cuz with a 180 it will just get hot then cool down then get hot again and cool down again and so on. so does the crate motor require a better water pump? cuz i put the oreilys one in for a 1995 silverado. any help would be absolutely amazing cuz im stumped now. thank ya
Old 10-30-2009, 06:14 PM
techinspector1's Avatar
Wiki Edits: 326
Start by reading through this checklist from the wiki.....
http://www.crankshaftcoalition.com/w...cooling_system
Old 10-30-2009, 06:15 PM
Jim Rockford's Avatar
World Famous VF-14
Last journal entry: Cleaned it up...
Install a 195 tstat.
Old 10-30-2009, 06:32 PM
sqzbox's Avatar
My pipes are my music
If you have and aftermarket temp gauge and put the sending unit in the head where the factory unit was, that's what will happen. Correct install would be on the front crossover coolant passage just ahead of the thermostat. Aftermarket temp gauge is more responsive to temp. changes than the factory electrical unit. Your getting added heat readings being picked up from the coolant passages in the head. If you don't have an aftermarket temp. gauge, Ignore everything I just said.
Old 10-31-2009, 09:08 AM
lol i do have an aftermarket gauge so i know im getting a good Reading. im really really stumped. its like the thermostat wont open but it does so i feel like i could possibly be te water pump so does a gm crate need a better pump than the original motor out of the truck?
Old 10-31-2009, 10:16 AM
327 / 350 hp's Avatar
Hi Red, Are you checking for coolant flow, 327/350 hp
gm 350 crate motor identification.. HELP !! ONEGALONLY Engine 1 05-01-2007 01:16 AM
350 crate motor problems cb50chevy Engine 2 02-14-2005 01:09 PM
Crate 350 vs. crate 350 JohnnyGTO Engine 7 05-02-2004 12:33 PM
350 sbc crate motor questions bentwings Engine 7 10-29-2002 09:03 PM
350 GM Goodwrench Caprice engine in 3rd Gen TBI F-Body? wrmason3 Engine 2 09-14-2002 08:01 PM
