GM CS130D alternator - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-13-2003, 06:00 PM
Red face GM CS130D alternator
Trying to install GM CS130D Alternator on my T-Bucket. Does anyone know how to wire this in? Presently have a one wire 12 SI 100A unit and need more output. This unit has 4 pins at the regulator, they are marked S F L P. Thanks
Old 07-13-2003, 09:30 PM
horvath's Avatar
Acoustic Rock ... for real.
Last journal entry: About Fusible Links
If it has 2 prongs top and a screw below that, the ALT EXCITOR wire (white) goes to the left prong ... the right prong gets a jump-wire to the screw and the screw gets wired to the ALT POWER wire(red).
Alan
54 Chevy Pickup
Old 07-21-2003, 11:34 AM
GM "CS" alternators
HORVATH, the answer you give is for the GM "SI" alternator which is a 2 wire hook up. The alternator I have is the NEW CS130D. Thanks any way. Which has a 4 wire plug, marked PLFS or PlIS.
Old 10-01-2003, 09:35 PM
Wires for alt...
go here for wireing instructions http://www.hotrodlane.cc/ONLINETECH/CS130DREG.html
Old 05-04-2011, 08:41 PM
Spindlevw,
THANKS for the link it was just what I needed. I am putting a 1988 vet engine in a 1946 truck. I found a serpentine set-up at a wrecking yard from a 1996 I think rear wheel drive chevy sedan. It has the newer alternator and I needed to know which wires to connect to make it charge. I think I burnt the regulator up from touching 12v to every terminal. So I think if I replace the regulator and connect all the wires correctly I will be charging up that battery.
Thanks
Scholman
Old 05-04-2011, 08:48 PM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Removal
MAD Electrical has a good article when it comes to 1-wire versus 3-wire alternators
Here's another related thread. 140 amp 10SI
Old 05-05-2011, 03:45 AM
SSedan64's Avatar
10Si & 12Si are 3-wire Alts.>> http://www.hotrodders.com/forum/atta...chmentid=54987
Old 05-05-2011, 05:00 AM
The CS 130D has a charge wire and a four conductor plug, but functionally you wire it like a SI series three wire. Two of the wires in the large plug on the CS 130 are not connected, so it ends up with only 3 wires.
You might also find this link useful. http://www.madelectrical.com/catalog/cs-130.shtml
Bruce
Old 05-05-2011, 05:58 AM
EOD Guy's Avatar
Diagram might help
Old 05-10-2011, 11:26 PM
All you REALLY need for a 130d and a cs 130 is the battery wire from the post going directly to the battery. Then run a wire off the ignition, thru an idiot light to the "L". Using the "I" wire too, is redundant. Don't use anything parallel to the coil if you have one.
Old 05-11-2011, 05:49 AM
malc's Avatar
Living At The Speed Of Life
Must be the oldest, 07-14-2003, thread ever reopened.
