The most common one used by street rodders is the 67-69 Corvette 427 435hp four wheel disc brake MC. It can be had in either power or manual. This is one example.
Vince |
I also had 4:1 pedal ratio and a 7" dual diaphragm booster. The same master cylinder with a deep pushrod hole and a 1" bore (different part #) can be used for non-power use. Pedal ratio will need to be 6:1 minimum with 7:1 being best. Both front and rear reservoirs will be the same size. |
Thanks guys, that's what I was looking for. I'm running a 8 inch booster our of a 64 Buick Special (that what came with it when I bought it!). The GM master cylinder bolts us to that nicely, but for whatever reason, I have to use a manual master cylinder with it because of the long pushrod on the booster. I have no idea what pedal ratio I have???? Anyone recommend the master cylinders on ebay?
I checked out the Corvette MC's. I noticed the ones for power brakes come with a bore size of 1 1/8". The manual ones come with 1.000". I have to use the manual MC for my booster. Is there a big difference between the 1 1/8" and 1.000" bore size? Will I be OK with the 1"? Any help is appreciated.
Why start a new thread and muddy the waters
Disc brake Master cylinder What exact (or as close as you can get) year/make/model/option are you running for: 1) Front Calipers 2) Front Rotors (or dimensions) 3) Master Cylinder 4) Booster 5) Rear Calipers 6) Rear Rotors (or dimensions) Is your e-brake hooked up? Does it hold well? How far down does the e-brake pedal go? Are you running any other valves in the brake lines other than the adjustable proportioning valve (like a stock combination valve)? Is the vehicle drivable other than the rear brake problem? If so how far down does the pedal go for an average stop? How much pedal effort is required for an average stop? Last edited by Triaged; 10-16-2008 at 01:41 PM. |
Front calipers - 74 Monte Carlo GM calipers Rotors- 11" F150 rotors. Master cylinder- GM Disc/drum- manual Booster- 8" 64 Buick Skylark special Rear calipers- 1985 Cadillac Seville Rotors- Cadillac rotors. 11" Ebrake hold the vehicle and I'm using Lokar cables. E brake is a handle not the foot pedal type. I get about 2-3 clicks max. I am only running a Wilwood adjustable proportioning valve which is currently wide open. The front brake work great, and is drivable. The pedal is firm and drops about a quarter of distance. Basically, the brakes work fine, just not utilizing the rear brakes when the brakes are applied or very little if any. I ordered the Corvette MC for disc/ disc and hoping that will cure my rear disc problem. Any other suggestions.... I'm listening! LOL.... |
I really don't think your problem is the master cylinder (at least replacing just your MC won't fix your problem). Your manual brake master cylinder most likely has a 1" bore vs the normal 1.125" bore for power brakes. However your booster is small so having the smaller master should balance it out ok.
Right away I see one thing. The front calipers are off a full size, while the rear calipers are off something that used smaller "metric" front calipers . So right off the bat you have some extra front brake bias. I'm not a big fan of calipers with the e-brake integrated. They often cause problems like you are having, however it seems like you have gotten the e-brake part taken care of. In 83 GM started using low drag calipers that retracted the pistons. To make up for this they used a step-bore (aka quick take-up) master cylinder. I don't know what they did to the rear calipers in this regard but it sounds like you might have a mismatch there too. You turned the prop. valve clockwise all the way in...right? If you put say 1 click on the e-brake handle will the rear brakes work off the hydraulics any better? Can you pump up the brakes and get the rear brakes to hold better? If so a 2# residual pressure valve in the rear brake line should help. As for the difference in caliper size you might look into using high friction pads in the rear while using low friction pads up front. Say an EE front and FF or GG rear. Basically a performance pad in the rear and a jobber/fleet pad up front. The parts guy will have to pull the box and you will have to look on the edge of the friction material...I don't think the edge code is in any parts book or online. edit If you want to change the master cylinder I would recommend going with a small 83-up double diaphragm booster/step-bore master combo and changing out your calipers to 83-up full size calipers. That would get you a light aluminum master along with the low drag calipers which would be good for both MPG & MPH. /edit From: http://www.satisfiedbrakes.com Quote:
Excellent source of information. Thank you. This is the information I have gotten from various guys who build hotrods for a living. I understand what your saying and it does make sense. Thanks. I was told, that my MC is a disc/ drum MC. which means the front will work sufficiently with the disc brake on the front end. The rear, which is drum, worked nicely when I was running drum brakes. I was told the drum portion has a built in 10lb residual valve in the MC, at the outlet. In addition, the drum portion of the MC will not provide enough pressure or volume to efficiently operate the discs, particularly with full size, Cadillac type calipers. I was told I have to have a 4 wheel disc/disc master cylinder and my brakes will work fine.
I also tried the method you described as clicking the ebrake slighly and then using the hydraulic. There was no difference. The MC is not pushing enough fluid to the rear calipers to push the piston out to the rotor. I also had a problem with the inline taillight switch which is in the line for the rear brakes. A Tee with the switch. With the drum brakes, I had no problem with the taillights functioning. When I converted to the disc in the rear, my taillights no longer functioned. They did come on if I stood on the brake pedal with tremendous force to build pressure in the line. The lights would come on. I wanted to make this easy, but sometimes that doesn't happen. I really don't want to invest in more money in new calipers, etc. I think my first attempt will be to try the disc/ disc MC and see if that works. If not, then I'll switch to different calipers. Or...... I can always reach down and pull the ebrake at every stop. I truly the appreciate the info you gave me and will keep it for future reference. Thanks.
The problem I was describing was NOT disc/drum vs disc/disc but low-drag vs non-low-drag setups. In fact if your master cylinder had a residual pressure valve in it that would be a GOOD THING! The problem is also not the rear brake calipers being too big but rather too small. From what you posted it was as if you took all I was trying to say exactly the opposite from how I meant it. How much was that new supposedly different by being a "disc/disc" master? Will they give you your money back after you install it and it doesn't help your problem?
I hate those hydraulic brake light switches. A switch on the pedal is the only way to go IMO. I would ditch it along with the prop. valve to eliminate as many variables as possible. Verify that there is no residual valve in the master cylinder while you are at it. |
I already got rid of the hydraulic switch and went with the mechanic on the pedal. Your right the hydraulic is junk. As far as the master cylinder, a friend of mine works in an auto parts warehouse and I can pick one up for $40. If it doesn't work, he'll exchange it. It's not that big of deal switching out the MC either. If that doesn't do the trick, I'll go to your recommendations. Again, thank for the help.
| 1977 Pontiac Lemans Master Cylinder Question | lew racer | Suspension - Brakes - Steering | 0 | 04-17-2007 04:33 AM |
| 1956 Buick Master Cylinder | PsychoBandito | Suspension - Brakes - Steering | 1 | 04-03-2007 12:36 AM |
| How Do I Hide Master Cylinder? | bob barker | Suspension - Brakes - Steering | 5 | 02-08-2006 05:19 PM |
| Single to Dual Master Cylinder | swazo | Suspension - Brakes - Steering | 2 | 10-19-2004 08:00 AM |
| Help with continuing master cylinder problem | chris57 | Suspension - Brakes - Steering | 3 | 09-30-2003 02:35 PM |
