Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - GM drum to disc swap
Old 06-07-2006, 05:21 PM
Triaged Triaged is offline
I don't know if it is in the rules but a residual pressure valve should help part of your problem. The 50's MC would just make things worse. If the peddle effort isn't too high you might try a larger (power brake) MC...but your rear calipers will still be too big.
