Gm E-brake Options - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-31-2006, 08:05 AM
ARPEE's Avatar
New Member
Gm E-brake Options
Having just read "MURRSUE's" request for help on a Ford based E-Brake, I thought my "find" might help someone looking for a unit to install into a GM 10 bolt/bucket seat floor mount.
While "harvesting" parts at the AutoWrecker for my '39 Chevy project, I looked at a floor mount system in a 2000 Honda Civic. To my surprise the entire arrangement, from floor mount lever > brake drum cable, was a bolt-in to my GM 10 bolt rear end. That is, cables from a Civic drum work in GM drum, and cables leading to the Civic floor mount lever installed my (Mazda 929) bucket seats are of suitable length, when installed to a '39 Chevy.
I know! I know! Mixing US and Off Shore parts -------- but, it works. And, for what it's worth, the e-cables/sheaths are, in my opinion, better designed. GM's are spiral wound, metal sheaths which, over time, would rust and seize up, while the ones I found are "neoprene/watertight" units.
Old 08-31-2006, 08:44 AM
STUPID is as STUPID does...
That's what hot rodding is all about now isn't it? I wouldn't hesitate to do the same thing if it works for the situation. Have fun!
Mark
Ford Galaxie Disc Brake Conversion CrashFarmer2 Suspension - Brakes - Steering 5 04-10-2010 04:52 PM
Need to rig up a park brake in the cab... murrsue Suspension - Brakes - Steering 5 09-03-2006 08:19 PM
Porportioning valve and brake switch mounting DDGETHS Suspension - Brakes - Steering 7 02-18-2005 12:51 PM
brake fluid rally4x4racer Hotrodders' Lounge 1 12-15-2004 04:54 AM
GM calipers - brake pads rattle! Limey Simon Suspension - Brakes - Steering 12 06-05-2003 08:25 AM
