Gm engine - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-01-2012, 01:55 PM
Gm engine
I have a Gm 400 v-8 with a 570 lift roller cam. When I turn it off the engine diesels. we have adjusted the timing and the carburator. It has hydronic roller lifters. What can be done?
Old 09-01-2012, 02:00 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
What's your idle speed and timing set at? I'm assuming it's also running rich.
Semper Fi
Old 09-01-2012, 03:36 PM
vinniekq2's Avatar
If it idles too high you can add an idle stop solenoid.Try fixing the problem first,,,carb/timing/cooling.
Old 09-01-2012, 06:41 PM
Idle speed is about 900. Timing is about 10 btdc. It is rich but runs good. Our vacuum manifold gauge suggests late valve opening. Plugs are black and sooty. I,question whether hydraulic lifters are adjusted properly. Only problem is when we turn it off there is no pinging or knocking. we have tried to,adjust timing to 6 - 15 degrees and everything in between and still had problem when we turned it off.
Old 09-02-2012, 10:33 AM
GM 400 engine
Sounds like it could be an ignition problem and fuel problem. Read this article it will teach you to tune your advance curve on your distributor. http://www.crankshaftcoalition.com/w...EI_distributor. Look at the section on Holley idle transfer slot. What happens is you don't have enough initial timing to keep the engine running. So what's the first thing you do, turn the idle screw on the carburetor to keep the engine running. What kind of carburetor are you using? What year is the motor. Is it high compression? Are you using GM heads. Pull the valve cover and get the casting # to find out what year. If it's a pre-71 use AC R43 plugs, Autolite 3014, NGK BR6S or 3522. If 1972 or later use R43TS, NGK UR4 or 2271, Autolite 24
350 Crate Engine: Loud humming sound after engine warms up sofa1515 Engine 2 01-11-2010 06:48 PM
Engine Help. Engine Turns over Hard, like siezed yet runs awsome. Merle9069 Engine 3 10-05-2008 06:38 PM
I need engine mount bracket ideas 1930 chevy with 302 boss engine. Riley Engine 3 07-25-2008 07:29 AM
Ford 302 engine to engine stand bolt size? Lee in Texas Engine 4 03-24-2008 10:30 AM
say you have a THOUSAND horsepower engine..... (technical engine question inside) lowROLLERchevy Engine 14 02-24-2007 08:26 AM
