gm engine ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-26-2003, 04:14 PM
New Member
Post gm engine ?
i just pulled of my heads and i had realized that 6 out of the 8 piston were black and crumy looking but 2 were not the front 2 on the passenger side were fine the driver side plugs were the worst and i had probally only put on 6000 miles on them they were all built up what causes this?
Old 01-26-2003, 04:37 PM
1BAD80's Avatar
The Smell of Nitro in the morn
Last wiki edit: How to adjust valves Last photo:
Wiki Edits: 2
Post
Chevy small blocks run lean on #3 and #5 normally. It sounds like to rich of condition. Carb not adjusted correctly or to big.
Clean on 1 & 3 mite of had a vacuum leak to run lean for the plugs to be clean. What kind of intake and carb are you running?
Luv the smell of NITRO in the morning.
Old 01-26-2003, 04:51 PM
BOBCRMAN@aol.com's Avatar
Post
bad valve seals and/or guides will also leave deposits, gasket leak or cracked head will clean off piston tops.
Old 01-26-2003, 06:31 PM
New Member
Post
I HAVE A EDELBROK PERFOEMER INTAKE WITH A 650 HOLLEY CARB, I AM TAKING MY HEADS TO GET THEM REDONE
« brakes | gm heads »
