GM Engine Code Test - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-16-2010, 12:46 PM
64Joker's Avatar
64Joker
GM Engine Code Test
I located these engine codes, can someone please identify the motor, year, car, etc. and send reference links for identification.
Located on passenger side, below cylinder head: F0422HF
Located on back end of top of block: 3868174
Thanks in advance
Old 06-16-2010, 01:05 PM
DoubleVision's Avatar
HF 65 327 Corvette 300 L-75 Manual 4-Brl AFB Carter
HF 66 327 Impala 275 L-30 Power glide 4-Brl Hyd Cam, A.I.R.
HF 67 327 Impala 275 L-30 Power glide 4-Brl Hyd Cam, A.I.R.
HF 68 327 Impala 275 L-30 T-H 400 4-Brl Hyd Cam
HF 69 350 Nova 250 L-65 Power glide 2-Brl Hyd Cam
HF 69 350 Chevelle 250 L-65 Power glide 2-Brl Hyd Cam
HF 69 350 Camaro 250 L-65 Power glide 2-Brl Hyd Cam
HF 78 350 Pontiac 170 LM-1 TH 350 4-Brl Hyd Cam, Firebird
I think you misread the casting number, I believe it`s:
3858174....327...64-67...2
Old 06-16-2010, 04:07 PM
64Joker's Avatar
64Joker
Re-check
You are 100% correct on the misread part! I double checked the casting number and it is 3858174. I purchased the car about 7 years ago with this engine in it, the car is a 1964 Impala SS automatic. I was advised the engine was a 327 (not the original block), but I never checked out the numbers. My body is not setup for air though!? Thank you for helping me out, what website did you use???
Old 06-16-2010, 04:15 PM
64Joker's Avatar
64Joker
Follow-up
What do the other numbers represent?
Thanks...
Old 06-16-2010, 05:09 PM
Probably mortec, but that site has been down for a while.
www.mortec.com
F= Flint (manufacturing plant)
04 = April
22 = day of the month
HF = the cars listed above ^^^.
Pull a valve cover. I'll bet you have "462's" on there.
Also, on the opposite side of the engine block (in the same area as the 3858174, but on the passenger side) there's a date code. It might be "D 22 7" or something like that.
Old 06-16-2010, 05:37 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Not "air" as in A/C.
The "A.I.R." referred to above is "air injection reactor", it was an early pollution control system that injected air into the exhaust manifold through a system of check valves and tubing, from a small air pump that was driven by the fan belt.
This was often one of the first things enthusiasts removed from their engines, the thinking being that this would increase performance- something that it actually didn't really do, the pump was not a big power robber and the air that was injected was post combustion chamber, so wasn't harmful to the engine's performance in that regard. But removing it was something that most any hack could do, so it was done. Often. And nowadays, finding an original system- intact- is all but impossible.
Old 06-17-2010, 09:17 AM
64Joker's Avatar
64Joker
2nd Follow-up
So basically, the block could be from any one of these vehicles or is there
a way to narrow it down?
Are there any other numbers perhaps on the exhaust manifold to give us more info? I appreciate all the help and additional information (A.I.R.).
Old 06-17-2010, 09:42 AM
The date code on the block would help narrow it down. The date code on the heads would help too, and also would tell if theyre the matching/original heads. If it still has the original exhaust manifolds, and it has the A.I.R. "tubes" on it, that would help too. Also check if there was a pilot bushing/bearing in it, as well as a clutch ball. If there ever were a pilot bushing/bearing in there, that would narrow it down too (assuming it's original).
Old 06-17-2010, 09:48 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
On the back of the engine, by where the distributor enters, there will be a date code. Something like D176, for instance. The letter is the month, the first number (if there's only two numbers, like D76) is the day, three numbers means the first two are the day, the last number is the year.
So D176 could be April 17, 1956, '66, '76, etc.
D76 could be April 7, '56, etc.
You can look on any cast part for numbers and date codes, there are info on most any SBC part that has a number.
acceleration flat spot in carb. corvettetonybone Engine 17 04-13-2013 08:31 PM
Pinging on 03 Chevy 5.3 Engine in Suburban bry21317 Engine 42 10-02-2011 07:35 PM
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
Valve Lash adjustment hiball Engine 36 05-11-2009 10:12 AM
1969 350 375HP GM Goodwrench Replacement Engine Big Daddy Teez Engine 2 03-21-2006 07:36 AM
