Gm engine interchangeability - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-17-2006, 07:35 PM
I have a 41 Dodge truck with an early 70s Camaro front end grafted on. It's currently set up for a big block Chevy. I have an opportunity to buy an Olds 455 with tranny that was in a Pontiac Trans Am. Has different or special mounts. With these mounts, will the Olds engine bolt into my setup? I have some big block Chevy mounts as well - would they bolt to the Olds engine so I could just drop it in? Any help is appreciated.
Thanks,
John
Old 06-18-2006, 07:02 AM
Hippie's Avatar
Last journal entry: HEI comparison.
Get the frame brackets and mounts for an Olds 403 powered '78-'81 Firebird or a '75-'77 Olds Omega with an Olds V-8. Engine swap headers for dropping the 455 into a 403 powered 'Bird may also be available and fit your setup. The 455 is taller and wider than the 403 so 403 headers won't work but the mounts should.
327 question adam15425 Engine 80 10-13-2004 09:22 PM
where to find GM engine suffix codes? 327amc Engine 1 01-04-2004 01:12 AM
GM Engine Color Change 1976 WHY??? Gearhead70Chevy General Rodding Tech 11 07-27-2003 07:07 AM
GM 350 Engine overheating wizofnet Engine 14 01-28-2003 01:09 PM
gm engine ? mr_dix7 Engine 3 01-26-2003 06:31 PM
