GM eSI DVD question - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-11-2007, 08:40 AM
GM eSI DVD question
I bought a GM eSI Factory Service Manual DVD for my daughter's 2004 Chevy Malibu and I must be doing something wrong with the installation on my PC. Does anybody have any experience with this?
Old 11-11-2007, 10:27 AM
Should have no problems installing it and running it as long as your "firewall" does not block it...
Old 11-12-2007, 07:10 AM
I went through the installation a couple of times (on 2 computers). On one I get a message about the Standalone application being installed and the standalone data files needing to be installed. The other computer starts the web browser and looks (in vain) for IP address 127.0.0.1 .
I get the feeling that I'm doing something in the wrong order... I ran the autorun files on the DVD, then copied the "copy to harddrive" folder to the hard drive, then ran the setup and update files on that. The instructions that came with the DVD are vague.
Old 11-12-2007, 08:08 AM
What operating system are you running and are you running a firewall??? 127.0.0.1 is a loop back to your own machine nothing to worry about. You will want to shut the firewall down for a few mins to install the software... You should have a disk labeled "application" thats the first disk to run...
Old 11-12-2007, 03:50 PM
One computer is running Windows 2000 Pro, the other one Vista Home Premium. I disabled the firewalls, anti-virus, and everything that wasn't absolutely necessary. In what order did you install everything?
I would think that the SI Stand-alone data that it's asking for would be the stuff that's in the "Copy to HardDrive" folder. These folders and files were installed in the C:\Program Files\GM SPO\eSI\SIROM\SIen folder (Db, R0, R1, R2, R2.1).
Old 11-13-2007, 06:49 AM
aminga's Avatar
Last journal entry: Cleaning and Powder coat
On Any computer 127.0.0.1 should be the loopback address and valid. It's the reference address for itself.
Old 11-13-2007, 09:56 AM
The eSI software has a web server (Tomcat) built into it to allow access to the files. The icon on the desktop opens the 127.0.0.1 address (the Tomcat server inside the computer), but it can't seem to open the eSI data files themselves from there. This is where it comes up and says that the Stand-alone data files need to be installed. I guess it could be looking in the wrong place for them.
Old 11-14-2007, 07:06 AM
After much searching, I found copies of the original paper GM eSI DVD installation instructions online... this looks promising. It says that the Java 2 Runtime Environment has to be removed before installation and that Microsoft .NET Framework 1.1 has to be installed. I'll have to try this again tonight.
Old 12-09-2007, 05:20 PM
Has anyone figured this one out yet? I just got the DVD and it just opens 127.0.0.....blah blah and it cannot find it. Anyone know what I should do?
Old 12-09-2007, 08:49 PM
I finally got it to work by loading it onto a clean install of Windows 2000 Pro. I made sure nothing else was loaded on the computer, loaded the Microsoft .NET Framework, eSI program, then loaded the anti-virus, firewall, MS Office, etc. Fortunately I had enough parts on hand to build the extra PC. It seems to work fine now.
Old 12-23-2007, 12:20 AM
This is a little amazing. I can buy downloading the .net -- which comes in 1.1, 2.0, and 3.0 -- all of which are supposed to be able to run on the same computer -- at the same time. ( I have 1.1 and 2.0)
Uninstallling the Java2.0 seems awfully strange -- unless the DVD requires a different version. Maybe it wants to install a different version ( which could be an earlier one), and it won't if one is installed. In my opinion that's a pretty bogus installation process.
Glad that you got it working.
ford2go
Old 12-23-2007, 09:18 AM
It might have been sensitive to the order in which they were installed. If I have the time, I might experiment with it... it's really the only thing I use that computer for.
mouse smell swvalcon Interior 18 03-14-2012 08:11 AM
7.625 GM Diff question???? mattmanuel Transmission - Rearend 1 08-11-2006 04:45 PM
91 gm 7.625 rear end question???? camaro420 Transmission - Rearend 2 05-01-2006 09:22 PM
GM HEI Distributor question Jag Daddy Engine 8 10-30-2003 06:12 PM
GM column size question 29 2dr sedan Interior 2 09-17-2003 06:06 AM
