GM flywheel casting numbers - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-14-2008, 08:27 AM
Sandflea427SS's Avatar
Anything with a throttle
Hello All
I have a few flywheels I would like to know what they originally came
on. I can't find the info I need on the net and don't have books that
cover them. Does anyone have any info for me?
I tried to decipher the numbers as best as possible, but some were rusty
and hard to read... They are as follows
L284 3714463
K292 3973456N
H275 3729004
2778819
Thanks for any help....
Old 11-15-2008, 12:13 PM
Last wiki edit: Calculating tire size
Last journal entry: Changes...
Wiki Edits: 2
3714463 seems to be 348ci / 409ci 168 Tooth
3973456N Internal balance 168 Tooth (BBC and SBC)
3729004 168T: 56-62, 77-78 vette, 59-64 Impala 283,348,409 except 425h/ used with 10" clutch
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 10:36 AM
casting numbers blf55 Engine 3 12-31-2004 10:45 PM
Need help with numbers on flywheel please?? Robbie Transmission - Rearend 2 06-06-2004 12:43 AM
Casting numbers for BBC GM Rect. port alu. heads sune Engine 0 05-11-2004 05:21 AM
GM head casting numbers? 14102183?? punk1c5040 Engine 2 04-27-2004 11:07 PM
