GM Fuel Tank Sender - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-05-2012, 03:43 PM
GM Fuel Tank Sender
Ok, I'm putting a 0-90 ohm Gm sender in my fuel cell (pro street Chevy Luv) and running one wire from the sender (from the post marked "to gauge") to the gauge (Autometer 3314). Does the other wire on the sending unit just go to a switched +12v? There is nothing on the sender saying where the second wire goes/comes from, and neither does the 1/4 page of instructions that came with it. I've never dealt with the electrical for fuel cells/senders and have no clue!
Thanks!
Smokey
Old 05-05-2012, 04:03 PM
powerrodsmike's Avatar
Wiki Edits: 161
If it is just a sending unit, (no pump), the second wire is connected to a good chassis or body ground. (12v -) A dedicated ground wire from the sender to the gauge ground is the best way to make sure you won't have gauge accuracy issues. You don't need a large wire, 18 or 20 gauge is plenty.
Later, mikey
BE different....ACT normal.
Old 05-05-2012, 04:19 PM
Cool deal, thanks. The fuel pump is external, so no issues there. Much appreciated, thanks!
Fuel tank sender farmall_560 Electrical 6 07-19-2011 11:15 PM
Fuel Tank Sender.. requires earth? duncan_m Electrical 2 08-02-2008 01:02 AM
Fuel tank sender 53 chevy propaneburner Electrical 4 03-10-2008 05:09 PM
gas tank pickup/sender MOD. frank88chevy Hotrodding Basics 1 01-12-2008 08:57 AM
Need Tank Sender for Custom Gas Tank.... bg Engine 3 11-05-2002 06:13 PM
