GM G-Body Rear Control Arm Boxing Kit? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-23-2002, 08:00 PM
Question GM G-Body Rear Control Arm Boxing Kit?
I'm looking for a boxing kit for GM G-Body rear control arms. I found an old add for a company called Chassis Engineering, but they said they don't make it anymore. Does anyone else know where I can find one? Thanks in advance for any replies.
Old 01-20-2003, 10:49 PM
Post
to box lower arms all you need is a 1.5" wide strip of .125" thick flat stock. you will need 20" for each side lowers. then bend end to match contours on end of arms then weld.
