GM gauge question - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-28-2011, 03:44 PM
GM gauge question
I'm using a gauge cluster out of an early 80's GM, Caprice I believe. New sending units the oil pressure works fine the voltmeter works fine the Water temp runs about 50 deg. high, the fan cycling switch comes on about 185-190 and the temp gauge reads 260, were there any other temp sensors? I thought they were all pretty much the same. It tracks nice and smooth just goes higher than it should. Any help would be appreciated. Thanks
Old 01-28-2011, 04:08 PM
LATECH's Avatar
Last journal entry: New Gas Tank
I found a chart that shows the resistance value for a given temp. I will try to post the link
Old 01-28-2011, 04:11 PM
LATECH's Avatar
http://www.lbfun.com/wharehouse/tech...s/Temp-sending -unit-and-gauge-CF-thread.pdf
Try this place ,it should help
Old 01-28-2011, 04:13 PM
LATECH's Avatar
linkie no workie
Just google : GM gauge sending unit values
It is about 5th or 6th down the first page look for the pdf one.
Old 01-28-2011, 05:10 PM
Thanks for the help, I now have a good place to start
Oil gauge question? Jag Daddy Electrical 2 03-19-2011 05:37 PM
Gas Gauge Question Retiredrich Electrical 3 05-06-2010 06:36 PM
After- market gauge wiring question 454 Rattler Electrical 3 02-21-2010 02:16 PM
Question about fuel gauge ??? Robbie Electrical 4 06-06-2009 08:31 PM
Quick Gauge Question. my350camaro84 General Rodding Tech 1 01-29-2006 09:25 PM
