GM headlight switch help.. - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-06-2008, 04:10 PM
Last journal entry: comming along
I have a headlight switch. I think it came from around a 1979 Pontiac Grand Prix. I also have the plug with wires on it. My question is where do the wires go?? I can't seem to find a wiring code for these wires.. Can anyone help me with this?? Thanks.. Al
ID:	33115   Click image for larger version
Old 10-06-2008, 04:42 PM
Black = To ground
Orange =From tail lamp fuse
Brown =To park lamps
Light green = To dash lights
Yellow = To head lamp dimmer
Red = From head lamp fuse
White = "Switched ground" to courtesy lights (One to the light and other can be split and sent to door pin switch/s. So courtesy lights can turn off and on when you open the door.)
Old 10-06-2008, 04:48 PM
302 Z28's Avatar
Beat me to it
Vince
Old 10-06-2008, 05:09 PM
Thanks.. I didn't want to have to buy a new switch.. Al
Trinary Switch from Vintage Air ElegantInventor Electrical 29 06-15-2011 06:44 PM
gm tilt column ignition switch mikoman Electrical 2 10-24-2006 06:38 PM
72 chevelle ignition switch assembly problems customdrumfinishes Electrical 9 08-10-2006 05:06 PM
Keeps Blowing Fuse hotrod48 Electrical 17 09-29-2005 12:20 PM
Headlight switch? CrashFarmer2 Electrical 5 12-11-2004 03:40 AM
