GM HEI distributor help with coil secondarys testing. makes no sense.
its a gm hei distributor computer controlled type.
When I was testing the coil I got .6 resistance between the BATT and TACH terminals. but when I touch the rotor button to the ground strap or the rotor button to the TACH wire It just says "1" on the meter. I don't understand this It's the same with 3 coils, 1 is new. I reused the rotor button and the ground strap. Can those 2 pieces somehow go bad somehow? This is bugging the crap out of me.
