GM HEI MSD 6AL- What coil do you run? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-22-2003, 07:32 PM
I have a GM HEI with an MSD 6AL but I have a stock ignition coil. I know they make the blaster external or the coil in cap design too (which is what I currently have in there) so what do you recommend?
Old 09-22-2003, 07:45 PM
s15laynrubba's Avatar
www.s10v8.com
I have been using the stock gm hei coil with my msd 6al for a little over 6 months without any problems.....Jay
Old 09-27-2003, 10:08 PM
New Member
HEI system is a good system, you do not loose any current through a non existing coil wire! I would recommend changing the coil however. Stock coils will not hold the primary voltage put out by an msd system, they will over heat and fail.
Best of luck
Old 09-28-2003, 04:33 AM
roys63's Avatar
Get the kit from MSD to move the coil out of the cap.
Old 09-28-2003, 12:08 PM
67malibuEFI's Avatar
I use the Accel super coil with my MSD 6, have had no issues.
Old 12-06-2003, 05:20 PM
I hate to bring up an old topic, but I have a 6AL, Timing Controller, Blaster 2 Coil and an HEI Distributor with a Dustcap conversion on my 70 T/A....
It works fine, but I'm about to start the restoration and I'd like the engine bay to look as clean as possible...
I'll be mounting the ignition and timing controller boxes in the trunk, but now I'm thinking about getting an MSD HEI coil (in-cap)....
Is there any difference in performance compared to the external Blaster 2 coil I have now?
I would think the HEI coil would be better do to less current travel...
Rick
