To begin with, check to be sure the HEI has battery voltage w/the key "ON", engine "OFF". If there's no power, the circuit is bad.
Be sure the rotor has been installed (don't laugh- guys have spent hours on an engine missing the rotor). If it has battery voltage (not less- the HEI needs 12 VDC at least for a good spark) and a rotor, but still no spark at the plug, the coil and module would be the next things to check. |
its getin power to the dist an ya the rotors there
tho i did notice that the coil's black wire i think its a ground was smashed the cap/dust but looks to have ben that way for bit |
g m hei problem
go to the junk yard pick up a ignition module swap it in.when they go there is no warning. make sure you get the one with the same amount of pins it only takes a few minutes to change
that article is some very interesting reading... |
| Testing GM HEI coil in cap | 75gmck25 | Electrical | 2 | 04-10-2011 12:55 PM |
| Recurving GM HEI for Supercharger | hduff | Engine | 4 | 08-31-2009 01:28 PM |
| GM pressures CorvetteStripes.com over trademark issues | Jon | Hotrodders' Lounge | 11 | 02-29-2008 04:04 AM |
| 350 Build.. Im sure there are plenty of threads on this... but this is specific!! | artillerystevens | Engine | 10 | 12-04-2006 09:34 PM |
| changing amount of advance on GM HEI | cool rockin daddy | Engine | 14 | 09-21-2004 05:16 PM |
