Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - GM Hei wiring
Thread: GM Hei wiring
Old 12-28-2003, 12:29 AM
jdcoic's Avatar
jdcoic jdcoic is offline
The Chicken Car
Yes, just one switched 12V wire is all you need. But, make sure you have eliminated or bypassed the factory ballast resistor (used on cars with points type distributors), and that the wire from your ignition switch is still supplying 12V while cranking, not just in the on position.
