GM Hydroboost - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-12-2005, 07:29 PM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
GM Hydroboost
Does anybody know what it would take to install a hydroboost setup on 69-72 GM pickups?
Old 09-12-2005, 07:31 PM
1931 steve's Avatar
Last wiki edit: How to rebuild an engine Last photo:
Wiki Edits: 4
Can I ask Why you would want to?
Steve
Old 09-12-2005, 08:16 PM
Blazin72's Avatar
Wiki Edits: 19
Partly because I am building an engine with a fairly big cam so it isnt going to have much vacuum and partly just a curiosity thing.
Old 09-12-2005, 09:11 PM
Ricky Rocket's Avatar
Drive it like a rental!
Hydro boost
I am not sure but you should be able to adapt a hydro boost assembly from a newer pickup into yours and route the hoses from the PS pump. I don't know if the PS pump is any different. I believe there were some vans that used this system also, they might be a little more compact.
Just throwing out some ideas and thinking out loud!
Rick
Old 09-15-2005, 09:17 AM
sbchevfreak's Avatar
Licenced Automotive Technician
The pumps are specific to hydroboost systems, but this shouldn't be too dificult a swap. Chev P/U's used it for years on heavy 3/4 & 1 ton trucks, as well as the diesels. Parts should be readily availiable.
How to properly mate a GM pump to a Mustang II rack Centerline Suspension - Brakes - Steering 73 10-31-2009 11:59 AM
Important Gm "factory Freak" Cars D M N General Rodding Tech 20 11-06-2008 07:25 AM
GM, Wake up ! onenew32 Hotrodders' Lounge 73 09-24-2008 07:33 PM
Back up on the dyno. MK2TMR2 Hotrodders' Lounge 33 06-23-2005 01:47 AM
Forged Crankshaft - GM 6223 or Eagle??? swerve Engine 5 04-14-2005 01:04 AM
