GM ignition wiring - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-21-2009, 09:23 AM
Last journal entry: 36 hemi chevy
GM ignition wiring
I have a GM steering column with keyed ignition, tilt and hi/low beam switch on the column (believed to be out of an 86 Corvette or Camaro). At the base of the column before it goes through the floor there is what looks like a square metal box with lugs inside. This is attached to the column. Is this the connection point for the battery feed to the igniton switch and accessory power?
cheers
Bill Marsala
Old 01-21-2009, 11:06 AM
C-10's Avatar
Revolution Calling
Last journal entry: Poverty caps live on.
Ignition switch: (?)
Neutral safety switch?
If you could post a photo, you'll get more specific info.
"Dollars are like votes, except that they actually count."
Old 01-21-2009, 12:29 PM
from your photos it appears to be the ignition switch (I've not had much experience with columns which come with keyed ignition). The terminals appear somewhat different. My plug (which is from a Painless Wiring kit from long ago) consists of 2 connectors; a black connector with a red (battery feed?) wire and an orange (accessory feed?) wire and a clear connector with a red (battery feed?) wire (joined together with the other red wire), a pink (ign feed?) wire and a purple (neutral safety switch) wire. Although the wires in the connectors may need to be switched around the match the ignition switch, can you tell me if the orange wire is the accessory feed to the panel and if the pink wire is the ignition feed to the panel. The orange wire appears the be 10 ga while the pink appears to be 12 ga.
cheers
Bill Marsala
"Wiring Harness" docvette Electrical 185 10-30-2011 04:17 PM
Mustang II ignition switch wiring John Hawes Electrical 1 12-09-2008 01:18 PM
GM switches and ignition again sha_ba_do_bang Electrical 2 10-28-2006 04:33 PM
gm tilt column ignition switch mikoman Electrical 2 10-24-2006 06:38 PM
56 ford ignition wiring m1e9r5c6 Electrical 4 03-21-2004 01:32 PM
