Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - GM LQ4 decoding
Thread: GM LQ4 decoding
Old 02-28-2013, 03:34 AM
jeepers creepers jeepers creepers is offline
Originally Posted by Hogg View Post
If the trans thats currently mounted on the engine is the original, the engine by simple deduction, the engine is going to be from a HD pickup truck as thats the only application that used this manual trans. The Duramax and the 8.1 engines came with the Allison Auto and the ZF S6-650 6 speed manual and only the LQ4 came with the NV4500.
From my post, if the LQ4 has iron heads, it a 99-2000 LQ4. If it has aluminum heads I can tell its a 2001-2007 LQ4. But the block casting number you supplied me only runs up to 2004 from what I can tell. So my educated guess is that you have a 2001-2004 LQ4 6.0 engine from a 2001-2004 3/4 ton or 1 ton truck.
the head code you supplied means nothing to me unfortunatley.
Why do you need the exact vehicle the engine came from if I may ask?
peace
Hog
Thank you so much for the info you gave me, engine is of a buddy, i don't know why he wants to know the exact vehicle that came from, i guess just to know the HP but it's just my guess.
Engine has alu heads so must be the newer model mountedn on HD trucks.
