GM manual transmission input shaft length - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-19-2011, 11:11 PM
With the bell housing off I am looking for a measuremnent from the front of the transmission case to the end of the input shaft on a Muncie or Saginaw.
Do they all have the same diameter pilot bearing?
Old 03-20-2011, 11:18 AM
The shaft is 6 5/8 in. the dia.is .593 all the same.
TH700r4 input shaft. vtech23 Transmission - Rearend 1 06-12-2010 11:31 PM
Question on 700r4 transmission tail shaft and front shaft eric32 Transmission - Rearend 11 05-10-2009 12:03 PM
loose input shaft fireguy Transmission - Rearend 2 11-26-2004 07:34 AM
input shaft 85 regal Transmission - Rearend 5 02-28-2004 08:46 AM
700r4 Input Shaft/Drum Interchangable to 4l65E Shaft/Drum?? syclone477 Transmission - Rearend 3 01-01-2004 04:06 PM
