GM master cylinder ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-06-2010, 01:02 PM
Marcel
Last journal entry: Choo-choo town
Which end of a GM duel master cyl. which is the front, or which is the back brakes? I want to install a line lock on the front brakes only. thanks
Old 03-06-2010, 02:31 PM
Frisco's Avatar
Glad To Be Here
On a disc/drum master, the larger reservoir is for the front disc brakes.
master cylinder plumbing maninacoupe Suspension - Brakes - Steering 4 11-07-2009 09:50 AM
Brake master cylinder problem ChrisMiddleron Suspension - Brakes - Steering 2 09-21-2006 03:39 PM
Single to Dual Master Cylinder swazo Suspension - Brakes - Steering 2 10-19-2004 09:00 AM
4 wheel disc master cylinder qckshftn56 Suspension - Brakes - Steering 2 05-23-2004 11:30 PM
Help with continuing master cylinder problem chris57 Suspension - Brakes - Steering 3 09-30-2003 03:35 PM
