GM Metric Brakes- What Year, Makes & Models Were they Used on ?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-25-2006, 07:03 PM
acr acr is offline
Title say's it all. I believe the years used were 1978-1988 but please correct me if I'm wrong.
Old 04-25-2006, 11:27 PM
Also all S10's except for 98-up Blazers.
Old 04-26-2006, 04:11 AM
acr acr is offline
Triaged, do you know what other specific GM makes/models they were used on? Thanks, acr
Old 04-26-2006, 09:01 AM
I always associated "metric" with G-body. So all the Regal, Monte Carlo, ect. of the era. I think you got the years right.
What is it you are trying to do?
Also in 83 GM went to calipers that would retract when the brakes were let off. To keep peddle travel down they also started using step-bore (aka quick take-up) master cylinders that were aluminum.
GM, Wake up ! onenew32 Hotrodders' Lounge 73 09-24-2008 07:33 PM
Pontiac will drop GTO this year ckucia Hotrodders' Lounge 10 02-22-2006 09:44 PM
Back up on the dyno. MK2TMR2 Hotrodders' Lounge 33 06-23-2005 01:47 AM
what was the strongest year 350 stock from gm??? joe28boxer Engine 24 12-17-2003 11:21 PM
converting GM 10 bolt to rear disc brakes, have questions HotRodF100 Suspension - Brakes - Steering 7 09-18-2002 11:22 AM
