GM metric calipers leaking.
Both the calipers are leaking where the banjo fittings connect.
I removed the fitting and the calipers look a bit rough where the aluminum spacer is supposed to seal. These calipers came with the front brake kit for a mustang II that I purchased from Speedway Motors about 5 years ago and I am finally putting it together. Just wondering if any of you have had a similar problem. Ed |
Try using the copper washers, also get thicker ones as they will help seal a rougher surface as they allow for more crush.
Thanks for the reply but I already tried that.
I had copper spacers the right size and they leaked just as bad as the aluminum ones. Ed |
Maybe the banjo bolt is bottoming out before it gets tight enough. Maybe check to see how far they screw in just to be sure.
i had the same problem from heidts.
the bleeder screws won't seal . i returned them and they sent new ones . no charge. |
| GM metric calipers | THERACER | Suspension - Brakes - Steering | 0 | 09-25-2011 09:37 AM |
| heidts with metric calipers and chevelle 11" rotors | THERACER | Suspension - Brakes - Steering | 4 | 08-22-2011 05:23 AM |
| Pinion seal on 8.2 10 bolt rear end leaking, replaced still leaking?! | artillerystevens | Transmission - Rearend | 6 | 04-10-2011 03:57 PM |
| GM metric rear calipers w/e-brake | bentwings | Suspension - Brakes - Steering | 2 | 03-31-2009 08:16 AM |
| vette calipers leaking,not piston | mikeweyman | Suspension - Brakes - Steering | 6 | 04-05-2004 05:20 AM |
