GM metric rear calipers w/e-brake - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-31-2009, 07:32 AM
bentwings's Avatar
bentwings
I have the GM metric rear calipers with the e-brake on my 9 inch Ford in the Willys. How do the e brake arms adjust. ?? Do you just rotate the arms and they screw out an adjusting nut on the inside.?? I can't seem to get them to grab hard enough to hold the car. I have the full Lokar floor mount e-brake system. Also they dragged quit a bit at first. Now they have loosened up a bit but still drag a little.
Old 03-31-2009, 08:02 AM
Frisco's Avatar
Glad To Be Here
I used those same rear disc brake calipers on my previous ride. They are difficult to adjust for the initial adjustment, but once that is completed they work well. See instructions below.
I also used the Lokar floor mounted emergency (parking) brake handle. I found that it doesn't have enough mechanical advantage to apply the pressure required against the discs. I made a lever to double the mechanical advantage. See sketch below. It is installed under the car between the Lokar emergency cable block and the emergency brake handle. This solved that problem.
Name:	brake bracket.jpg
Old 03-31-2009, 08:16 AM
bentwings's Avatar
bentwings
Thanks for the quick reply. Just what I needed. Looks like an all afternoon job just attempting to adjust them. Then another afternoon modifying and remounting the brake handle. Guess that's what hotrodding is about. Wouldn't be any fun if things just bolted together and they worked as planned. haha
master cylinder interchange runn141 Suspension - Brakes - Steering 7 05-03-2009 05:15 AM
Master Cylinder Question! bluesman123 Suspension - Brakes - Steering 37 08-16-2008 01:18 PM
Need 1990 Bronco II Rear Brake Help LarryA Suspension - Brakes - Steering 0 04-02-2007 08:38 PM
My 9inch rear end disc brake setup. 1937FordCoupe Suspension - Brakes - Steering 0 01-15-2007 06:01 PM
gm truck rear end rhett Transmission - Rearend 6 06-18-2003 04:11 PM
