gm metric rear-ends - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-10-2006, 11:44 PM
cardaddyo's Avatar
always the hard way...
gm metric rear-ends
what years of vehicles(bodies)had the METRIC gm rearend?was it just the bracketry,or is it a specific rearend,that is metric?any and all you guys have would be appreciated, thanks
Old 03-11-2006, 01:30 AM
M&M CUSTOM's Avatar
Wiki Edits: 9
I have never specifically heard of any GM axle called the "metric rearend", but the only one that immediatly comes to mind is the Borg Warner 9-bolt with a 7.75 inch ring gear, commonly referred to as the "Austrailian axle", and it was only found in some F-body cars for only a few years.
Old 03-12-2006, 12:39 AM
cardaddyo's Avatar
speedway has a ******* 9',axles,everything,but w/ gm metric bracketry.$800. just the housing w/axle tubes,$459-499. my whole front susp is direct replacement for 78-88 g-body,but all hardware(nuts,bolts)were metric.so i just wanted to know if my rear-end was metric also.
Old 03-12-2006, 01:12 PM
M&M CUSTOM's Avatar
Wiki Edits: 9
Sounds kind of like you have the same thing I have, my Malibu is the last year they called the A-body a rear wheel drive, and the 82 midsize cars were given the G-body designation.
I have the last year of standard measurement wheel studs and many other things with mine being an 81, but there were many screws and bolts here and there ther were changed over to metric stuff on mine.
They changed more and more as the years went on, but you should still have standard measurement stuff even if it is bolted in with metric hardware.
Rear ends... chrisflock Transmission - Rearend 12 06-04-2005 09:05 PM
rear ends that re 54-56" wide outside of drum firebikes Hotrodding Basics 6 02-12-2005 11:55 AM
gm 12bolt rear interchange Walker Transmission - Rearend 5 01-21-2004 02:01 AM
Mopar Rear Ends phatwagon Transmission - Rearend 2 04-24-2003 02:13 PM
Rear end swap problems datsun dale Transmission - Rearend 1 12-17-2002 10:50 PM
