GM Motor Differences? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-16-2003, 01:59 PM
Jag Daddy's Avatar
1969 Mustang Coupe Project Car
Last journal entry: New Project Mustang, From Jag Daddy to Stang Daddy
Question GM Motor Differences?
Ok I have a question, GM makes a lot of products i.e. Chevy, GMC, Pontiac, Cadillac, Oldsmobile etc. Whats the difference between the power plants?
For instance do they use the same blocks? If not what's the difference?
Regards
Mark
Old 09-16-2003, 05:49 PM
Basically everything is different with the exception of chev and gmc. since the late 60's their motors have been shared. As for caddy's olds pontiac and buick their motors have little in common.One could talk all day about all the differences and they all have their own strength and weaknesses
Old 09-16-2003, 06:05 PM
Vern Bradford's Avatar
In the 60's and 70's the different divisions did have different motors. Chevy had their own 350, Pontiac and Olds had theirs. I think it was in the early 80's that they started sharing Power Plants. When one of the divisions develop an engine they have exclusive use of that Power Plant for either three or four years, I forget exactly how long. That is why it took Chevrolet so long to finally get a good V-6 for their Camaro. After the alloted time they were allowed to put the Buick 3.8 Liter engine in it. GM is strange.
Vern
Old 09-16-2003, 07:15 PM
To be completely accurate gms devisions started sharing engines in the late seventies. The buick 3.8 that you mention from the camaro has been around since the 60's and in fact the rights of it were sold to jeep for a while until they were bought back by gm in the late 70's.
Old 09-16-2003, 09:11 PM
BOBCRMAN@aol.com's Avatar
When dealing with later model GM engines you have to divide the engines up in "familys" Mostly determined by what division produced or designed the particular piece. examples 2.0-2.2 OHV 4, 2.8-3.1-3.4 V-6, are designated as Chevy along with the 4.3 V-6 and the large and small block V-8's. 2.3-2.4 Quad 4 motors are Olds design, along with the Arrora V-8,. 2.5 Iron motors are of Pontiac design, 4.6 V-8 is Cadillac along with the 4.1-4.5 V-8's. 3.3-3.8-4.0 V-6 are Buick designations.Then you get into the half breeds,1.0 GEO (Suzuki), 2.0 Brazillian, and a host of other Toyota-GM-Isuzu and various Korean companies tha GM has partnered with.
Thats why when you need a part or engine, you have to have the Vin Code to get the correct parts. When you get into the GEO stuff you will find three different engines used in a model in the same year, all the same size but from a different manufacturer.
Old 09-17-2003, 12:18 PM
Jag Daddy's Avatar
So if I were to try to use a Pontiac block would it match up to say a 700r4? What is a comparable engine to say a chevy 350?
Regards
Mark
Old 09-17-2003, 12:45 PM
Sandflea427SS's Avatar
Anything with a throttle
I think the 700 was mostly only Chevy....
The 200R4 was more common with the dual bolt pattern BOP and Chevy.
Don't know much about the BOP small blocks...
Chevy and 455 Olds are all I know...
Old 09-17-2003, 04:05 PM
200-r4 where available in either a strictly chev pattern or a dual bolt pattern. I was about to say that 700-r4's are strictly chev but I though I remember them being offered with the 350 olds diesel.
Old 09-08-2004, 07:49 PM
M&M CUSTOM's Avatar
Wiki Edits: 9
Olds Diesels had the 2004R behind them. I had two of them over the years. If it wasn't the 2004R it was the BOPC 400 from my experience.
They might have had the 350 tranny behind them, but I haven't seen that as of yet.
The 700 is a Chevy only bolt pattern, or 2.5/2.8/3.1/3.4/3800 Gen II bolt pattern.
Old 09-09-2004, 05:25 AM
New Member
While it's true the 700 won't bolt right up to a true Pontiac block there are adapters readily available:
http://store.summitracing.com/defaul...+trans+adapter
Just as an example.
But what do you mean by "comparable engine to say a chevy 350"?
Inch for cubic inch the Pontiac motors will create (typically) more torque than the chevy small block as they have a longer stroke which starts at 3.75" for the Poncho 350. The SBC will rev higher and create more HP, typically at lesser expense with after market parts.
