GM New Process A-833 4 Speed OD Trany - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-07-2013, 09:56 AM
I recently acquired a GM New Process A-833 Transmission. Apparently this Transmission was used in 81-87 Chevy Pick Ups and Vans. I also noticed it was used extensively by Chrysler. Here's my problem. I don't have a shifter for this transmission and was wondering if the Chrysler version would work? I see a lot of listings for that shifter, but non for the GM version.
Thanks, Zooma
Old 04-07-2013, 10:11 AM
Wiki Edits: 85
Probably not.
Do you have the 81 (Aluminum case) Chevy A833 or the 82-87 (Cast iron case) Chevy A833? Is it 2wd or 4x4?
I have both versions in 2wd, and may be getting a 4x4 cast iron version today from the swap meet. Without looking I don't know if any of them have shifters still on them.
Be super careful with your transmission when you handle it. If you break the front bearing retainer, you will not be able to replace it. Both of mine were sold years ago and I have not been able to find ANY replacements.
Old 04-07-2013, 10:24 AM
4spd
Thanks, Zooma
that trans was made by a division of chrysler.had 1 in a 1995 gm pickup,it is defently a truck trans and not a nice shifting ,but strong enough.the truck trans and the trotle bodeyed injection 350 was a vehicle i will not miss.
Old 04-07-2013, 02:39 PM
Aluminum Case
MMerlin, I have the all aluminum case 2WD unit that is complete except the shifter. I noticed the Chrysler mounting plate is different than the GM version, looks lower and the GM version is quite higher. If all else fails, I'll fabricate the mounting plate and try to make a Hurst Shifter work.
Thanks
Old 04-07-2013, 03:13 PM
RWENUTS's Avatar
Here's a link you might find interesting.
http://67-72chevytrucks.com/vboard/s...d.php?t=574221
Old 04-08-2013, 11:59 AM
The OEM shifter was made by Hurst. 833s in general were not the fastest shifting gearboxes. I would contact Jamie Passon; he does a lot of 833 boxes and used to deal in the OD parts as well. He may have an OEM chevy shifter kicking around he'd be happy to move.
Old 04-08-2013, 04:52 PM
Thanks for the link and info to contact Jamie. I will get with him and Music man on the forum for shifter info
Old 04-09-2013, 12:59 AM
Wiki Edits: 85
I checked my transmissions. The aluminum box is missing the shifter.
98 mustang 5 speed trany hotdam Transmission - Rearend 2 09-16-2010 07:13 PM
chevy 4 speed trany will it work highspeedchevys Transmission - Rearend 1 04-22-2007 07:48 PM
SM465 4 speed trany to a t-400 , Want to Keep the 205 t-case MAYNARDTRUCKIN Transmission - Rearend 2 04-21-2007 12:18 PM
58 Hemi to A 833 salemlampworks Transmission - Rearend 1 10-08-2006 09:21 AM
Low on trany oil.... sliping trany? BadBowTie Transmission - Rearend 2 03-10-2002 07:34 PM
