GM NWC T5 rebuild Q - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-07-2011, 11:55 PM
GRIdLOCK's Avatar
project pegasus{(([cloaked]))}
GM NWC T5 rebuild Q
I have my T5 torn apart and now just starting assembly, I am now at the 3-4 gears slider and the keys dont wanna cooperate, the keys in the 1-2 slider is working great sliding back and forth between the gears but when I install the front shaft connecting the 4th gear to the 3-4 slider and pull it into 4th gear its almost like it slides a little to far and the keys ever so slightly kick out by the 3rd gear brass synchro, would this be because I dont have it installed and this is allowing the 3-4 slider to over extend on the shift into 4th? I am just trying to make sure everything is perfect before I get it all the way back together.
Has anyone ever had this problem or ran into this with one of these trannys?
Im sure its something small but thought I would ask here before I pull it back apart for a 3rd time
Thanks
ps I bought the master rebuild kit and am using new parts
4L60e, to rebuild or not rebuild, that is the question ? old yukon Transmission - Rearend 31 04-07-2011 12:25 PM
SBC 383 rebuild #3 y2k600f4 Engine 5 07-26-2009 03:38 PM
318 rebuild jmplimmer Engine 1 10-24-2006 08:31 AM
To rebuild or not to rebuild - Engine (and Tranny) KristensRanchero Engine 13 09-07-2004 01:20 AM
Tear down 1st rebuild and rebuild again help.... HemmiGremmie Engine 10 08-20-2002 10:29 AM
