GM Option Codes - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-25-2006, 07:04 AM
GM Option Codes
A while back while searching this site I came across a comprehensive list of GM Option Codes that someone had posted. Now I am trying to locate it but I can't seem to find it. Can someone direct me to it so I can print off the codes for future reference? Thanks!
Old 05-25-2006, 11:13 AM
Jon's Avatar
Jon Jon is offline
Hotrodders.com Administrator
Wiki Edits: 7314
Have you checked the Hotrodders Knowledge Base?
Old 05-25-2006, 11:35 AM
malc's Avatar
Living At The Speed Of Life
GM Option Codes found with the search button
Old 05-25-2006, 11:41 AM
Gm Option Codes Found
Thanks for the help!! I've found them and printed ta copy of them!
GM 5.7L crate engine suffix codes SCRUBBY Engine 2 11-30-2009 04:36 PM
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
GM transmission codes scot Transmission - Rearend 3 04-27-2005 07:02 AM
gm paint codes defilade Body - Exterior 2 09-26-2004 01:46 PM
GM 12 Bolt Housing Codes jbspringer Transmission - Rearend 0 10-03-2002 03:43 PM
