Should have what you need here.
http://www.speedwaymotors.com/Street...Hose-Kits.html maybe these>> http://www.speedwaymotors.com/AN6-Fi...isplayId=27978 |
power steering pump.
Hi,you need to replace the GM valve,with one from summit or speedway.in the original valve ,the hole is too big,which,with the mustang 2,makes the steering flaky (for lack of a better term) maybe faster? anyhow this valve slows down the steering input.
We have had much better luck with the o-ring fittings than the banjos. The problem with using a flat washer is the rack body has to be 100% true in order for it to seal. Which 1/2 of the time isn't the case. |
| Mustang II Power Steering Rack | Dave42 | Suspension - Brakes - Steering | 7 | 02-13-2006 05:26 PM |
| Flaming River Mustang II Power Rack? | acr | Suspension - Brakes - Steering | 1 | 02-19-2004 05:57 AM |
| Are Mustang II Crossmembers Safe? | Jon | Suspension - Brakes - Steering | 14 | 10-17-2003 12:43 PM |
| mustang II streering rack help needed | stea | Suspension - Brakes - Steering | 4 | 07-22-2003 11:12 PM |
| Lean backfire | Camaro76 | Engine | 5 | 04-15-2003 05:45 PM |
