GM Phase 6 Bowties on 327? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-21-2009, 09:47 PM
Hacksaw's Avatar
BOOMER SOONER
I ran across a set of GM Bowties, phase 6 aluminum heads. Will they work on my 1970 350 block? I run a 1968 327 crank and rods with trw flat top pistons, 4 valve reliefs. The heads are said to have 55cc chambers, 2.02/1.6 valves. Will this make my compression to high? With a 64 cc head, the specs from trw are 9.18:1
Old 02-22-2009, 01:09 AM
DoubleVision's Avatar
The compression ratio I get using a typical .041 thickness fel pro gasket and a guessed figure of a .025 deck clearence the compression ratio comes in at
9.8:1, slightly on the high side but liveable on 93 octane fuel, especially with a tight quench distance.
Old 02-22-2009, 09:16 PM
Hacksaw's Avatar
BOOMER SOONER
My engine is a .060 bore. Any idea what this will be on compression? What cam should I run? I have a manual 4 speed trans in a 64 nova about 2800 lbs. With 4.56 rear gear. It is a street car. But I want to run the biggest solid lifter flat tappit cam that I can. What about intake? What should I run? Are these heads going to work good??? Thanks
Old 02-22-2009, 09:18 PM
Hacksaw's Avatar
BOOMER SOONER
I forgot something. The carb is a new Holley 650 mechanical hp street.
Old 02-22-2009, 10:10 PM
techinspector1's Avatar
Wiki Edits: 326
I researched these heads a little. It seems that they were cast by Brodix for Chevrolet and were used on the NASCAR circuit until the raised runner heads arrived on the scene. The runners are 180/55. The specs call for 55cc's, but that was with flat-face valves and before machine work. I suspect the ones you have, if they have conventional dished valves, are closer to 60cc's. "Must be used with 14011051 guideplates and 10051155 3/4" head bolt washers". May need offset lifters.
Found some flow figures, but nothing less than 0.400" lift. I guess when you consider these heads were destined for 355 motors that revved to 9500 and used ??0.750"?? valve lift, there was no reason to list low-lift flow.??? At any rate, they flow worse than the L31 Vortecs on the intake side at 0.400". Exhaust flow is exceptional though. If I were bolting them on my motor, I'd want to know the flow at 0.100", 0.200" and 0.300" as well as the rest of it.
0.400" 222/169
0.500" 247/188
0.600" 262/199
0.700" 274/205
0.750" 280/204
Old 02-23-2009, 06:33 AM
Hacksaw's Avatar
BOOMER SOONER
Man, I looked on the net for info on these heads and never found that info. You sure know how to find that stuff out! Thanks. I sent you a PM as well Techinspector. I already have the recomended guide plates that come with the heads. Any idea about the rocker studs? Will any 7/16 stud work? Also, what is a offset lifter?
Old 02-23-2009, 10:09 AM
Wiki Edits: 326
See the bottom right hand corner of page 244 here....
http://www.compcams.com/technical/Ca...07/242-247.pdf
Old 02-23-2009, 04:12 PM
ericnova72's Avatar
More for Less Racer
Inspector, the flow #'s you've listed are for a fully ported head right?
We have run two sets over a flowbench in their out-of-the-box condition and they didn't come anywhere close to the numbers you put up. I remember they were only in the low 220's cfm peak on the intakes, they were worse than Vortecs. I was told that the port coring was the same as Iron Bowtie, and the low #'s made sense with that statement. Phase 6 aluminum's are cast thick everywhere to allow head porters to carve almost whatever port shape they want(within reason) and so are not very good in as-cast form. I know it took us a lot (A LOT) of time grinding to get the intake #'s up to 270, but the exhausts were easy to get 200. I wouldn't recommend these to anyone to use out-of-the-box unless class rules said no porting and factory part #'s only. Aftermarket heads are a much better place to start, with a lot less finishing time.
Old 02-23-2009, 06:53 PM
Wiki Edits: 326
I have no clue Eric, I was just trying to make sense of them. What you're saying about being slugs out of the box and thick cast to allow porting makes perfect sense.
How to properly mate a GM pump to a Mustang II rack Centerline Suspension - Brakes - Steering 73 10-31-2009 11:59 AM
chevy head and cam suggestion needed for 327 Berliner Bel Air Engine 3 12-06-2004 09:44 AM
327 GM stock aluminum intake. slider in wa Engine 2 10-25-2002 04:38 PM
327 rebuild help. SUGGESTIONS PLEASE DeezImpala Engine 1 06-24-2002 09:06 PM
327 or 350 ? HotRodS10 Engine 3 05-06-2002 08:15 AM
