Gm piston number what does it mean - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-03-2013, 06:54 AM
I have a gm piston. just try to figure out what the numbers on the bottom of the piston means 3991476 60 thanks.
Old 02-03-2013, 10:13 AM
vinniekq2's Avatar
contact fbird88 I think he has used these pistons
Old 02-03-2013, 01:26 PM
BigEd36's Avatar
From searching online I can't find much about that casting number, but Silvolite shows a piston replacing that part number, it's either 11 or 13 cc dish piston, Silvolite's version is 1.54 compression height instead of the factory 1.56 so they would be considered "rebuilder" pistons that will give you .020" more "in the hole" or piston deck height than standard pistons. The 60 at the end of the number probably means they're .060" overbore sized.
Old 02-03-2013, 02:33 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
I'd tend to agree w/BigEd36- Silvolite Pistons, bottom of the page. Two possibilities are shown, one has a 0.070" deep dish, the other a 0.080" dish. Both are available 0.060" over. The numbers shows up under "O.E. Casting No."
If these are original pistons, they should have a CH of 1.56". But if they're aftermarket replacements, they're prollably going to be the shorter rebuilder type.
Old 02-03-2013, 08:11 PM
The 60 is under the the rest of the number . What do you mean ch of 1.56
Old 02-03-2013, 09:44 PM
BigEd36's Avatar
CH - Compression Height - is the distance from the center of the piston pin to the top of the piston. 1.56" is the compression height of a standard 350 piston. Many aftermarket pistons are what's called "rebuilder" pistons, they are only 1.54" compression height, or .020" shorter. The reasoning is that it's assumed when the engine is rebuilt the block will be decked, so making the piston shorter will keep the piston deck height (the distance the top of the piston is below the top deck of the block) will be the same. If your engine is rebuilt using "rebuilder" pistons and the block is not decked, now your pistons will be .020" further "in the hole" (down in the cylinder). That will lower your compression ratio, and add .020" to the squish/quench height (distance from the top of the piston to the cylinder head) which makes an engine more likely to have detonation problems or require higher octane gasoline to prevent the detonation.
Old 02-04-2013, 05:25 AM
Thank you
Piston ID number goodnigh Hotrodding Basics 3 07-03-2012 03:03 PM
Piston number question kohle1ce Engine 3 04-30-2006 02:34 PM
piston number 78 chevy truck Engine 27 06-24-2004 01:26 AM
piston part number confusion Sleeve396 Engine 0 04-13-2004 10:03 PM
piston number 78 chevy truck Engine 1 01-24-2004 10:44 AM
