GM posi - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-15-2010, 09:49 AM
GM posi
I have a 8.2 10 bolt rear----anyone know if posi # 410409N GM 7 J3 is the right unit for my rear,and if so what gear ratios will it accommodate?
Old 07-15-2010, 10:08 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Actually, that comes up as a 2-series 8.5" 10 bolt corporate rear end casting. Check to see if the bolts that hold the ring gear on are 7/16" LH threads.
Old 07-15-2010, 11:08 AM
big gear head's Avatar
High Performance Rear Ends
Yea, that's a 8.5 2 series posi. It won't work in the 8.2 rear end.
Old 07-15-2010, 11:46 AM
Thanks,guys. Thats what I thought from my research,but the thing is on E-bay and the guy insists its an 8.2 . Don't think I will pursue it any longer
Thanks again
Old 07-15-2010, 11:52 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
8.2" 10 bolt
Casting # Series Gearing
ED32118 2 2.73:1 & down
EDB30116 3 3.08:1 & up
ahhh what do I do? mixed up beraing cups, budget 8.5" posi install Warrant Transmission - Rearend 7 03-23-2007 08:39 PM
Best Posi Carrier for GM 10-bolt leejoy Transmission - Rearend 7 09-08-2006 09:22 PM
Where can i get a posi Dreadlord Transmission - Rearend 9 01-20-2004 08:15 AM
8.5 GM 10 bolt posi musky2 Transmission - Rearend 1 12-25-2003 10:57 PM
97 GM posi question chevypu Transmission - Rearend 0 06-18-2002 04:43 AM
