GM makes pretty good posi units. I would think you'll be fine but keep in mind that anything used is probably going to need to be rebuilt first.
10 bolt 8-1/2" 28 spline
I've got a Gm 10 bolt 28 spline 8-1/2" locker for sale for 100 bucks..
I replaced my GM Eaton style with a Detroit Truetrac: http://www.tractech.com/Products.htm
Awesome unit for a street car, very smooth power transfer, no clutches, no cones, no ratcheting and no limited slip fluid! |
Check the casting number on the unit to see if it's compatible with your gears. If it says 410409, it's a 2-series, and won't work with 3.73's. If it says 410408, it's a 3-series, and should work fine.
Series 2 Or 3
It says neither 410409 or 410408
the ONLY numbers on it are as follows: (all are on the opposite side of where the ring gear would be (i guess passenger side of the carrier)) in large cast numbers appears 04-6 in smaller cast numbers appears both 8Y, and 18D (maybe 8D) and in stamped numbers appears E61 E61A no other numbers appear on the entire carrier what do you think I have??? eaton??? GM??? series 2 or 3 ???? Last edited by TORI1; 01-27-2006 at 08:08 AM. |
| Need Gm posi info | musky2 | Transmission - Rearend | 1 | 12-11-2005 02:21 AM |
| 12-Bolt Posi GM | djjc76 | Transmission - Rearend | 3 | 07-23-2005 11:42 PM |
| stock GM vs. aftermarket posi | red_rider52 | Transmission - Rearend | 7 | 02-28-2005 05:50 PM |
| GM 10 Bolt Diff w/ Auburn Posi | k6qk | Transmission - Rearend | 10 | 12-17-2003 07:45 PM |
| Posi Units for a GM 10 Bolt | bizkit075 | Transmission - Rearend | 1 | 04-28-2003 07:04 PM |
