GM Power Steering Pump Leak - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-11-2007, 08:26 AM
I apparently have leakage of hydraulic fluid from the pump or reservoir on my 1987 Cutlass. The lines on the back of the reservoir appear to be dry and not the source. The bottom and lower sides of the reservoir are moist.
Where due these leak from, and does the whole reservoir/pump assembly need to be replaced?
John
Old 12-11-2007, 08:34 AM
poncho62's Avatar
Wiki Edits: 5
Probably leaking from the bearing seal behind the pulley.........
Old 12-11-2007, 08:36 AM
31 five window
Last journal entry: grill and rear end
The reservoir seals to the pump with a big o ring. Remove pump and fitting that holds on cover then slide off cover and change o ring . the cover just slips back on fairly easy if you oil the o ring.
Old 12-11-2007, 08:41 AM
Will I need to disconnect the hydraulic lines and remove the pump and brackets from the engine to separate the pump and reservoir? Also, will the pulley have to be removed from the pump shaft?
Thanks,
John
Power Steering pump help 1952_Chevy_Panel Suspension - Brakes - Steering 2 01-17-2007 04:56 PM
Help! How do I install a new power steering canister to my existing pump? boricua_stang Suspension - Brakes - Steering 1 10-02-2003 06:48 PM
Hotrodders Knowledge Cluster: Power Steering Conversions Jon Suspension - Brakes - Steering 0 09-03-2003 11:20 PM
Power Steering Pump Problem... IWasBlown Engine 1 04-07-2003 09:03 PM
power steering pump impala dreaming Suspension - Brakes - Steering 3 02-15-2003 05:00 PM
