gm power steering turns to left by itself - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-11-2004, 08:41 AM
Black Sheep's Avatar
See you on the street...
Exclamation gm power steering turns to left by itself
We got the '58 chevy truck fired up yesterday and everything went well until I topped of the power steering fluid (using a 75 Nova front sub)
When I added fluid the steering turned to the left and locked up. With the engine shut off it's still locked up. Any idea what causes this? I assume it's in the steering gear itself.
Any help is appreciated...
Old 10-12-2004, 12:33 PM
astroracer's Avatar
You've probably got the pressure and return lines from the pump to the gear hooked up backwards...
Old 10-12-2004, 01:46 PM
Thanks Astro, others have told me the same thing. It's my brothers project and I'm trying to get it sorted out for him so he can start driving it. I pulled the lines off and they're two different sized flare fittings. Right now he's got the pressure line connected to the larger sized lower fitting. It's a "Johnny Cash Special" so who knows what he's got going. Can someone with a Saginaw steering gear check their power steering plumbing? Let me know which port is which...
Old 10-12-2004, 05:27 PM
Last journal entry: More propane stuff
Generally with all hydraulic systems the smaller is the high pressure side and the large is the return.
Old 10-16-2004, 04:34 PM
Just an update. The steering gear was FUBAR. We installed a remaned box on Friday night, it works like a million bucks...
Old 10-17-2004, 09:19 PM
sbchevfreak's Avatar
Licenced Automotive Technician
I was goin to say that the spool valve was probably hooped...
