gm rear axle ratio/rpo codes - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-07-2013, 12:06 PM
I have a1985 IROC-Z28 with rear axle ratio of 3.42. My rpo code is GU6. A rpo G92 performance axle ratio is also a 3.42 but concidered as being only 250 cars produced. Does anyone know if there really is a difference?
Old 04-07-2013, 04:52 PM
big gear head's Avatar
High Performance Rear Ends
I don't know about the G92 code, but someone here might have a good answer for you. Transmissions and Drivetrain - Third Generation F-Body Message Boards
Old 04-07-2013, 07:39 PM
thanks very much. I have tried this site before but navigation was impossible. I will try again.
Old 04-07-2013, 07:41 PM
Wiki Edits: 31
"G92 : AXLE REAR RATIO, PERFORMANCE" from RPO Codes.com- GM option codes,GM rpo codes,General Motors options
It doesn’t give the ratio. However GU6 is the code for 3.42 and that would normally be paired with G80 if it had a Gov Lock but the F bodies got Ford Trac locks, so possibly the G92 was an odd code for 3.42 trac lock
Old 04-07-2013, 08:03 PM
Thanks for the info. I never knew they used Ford carriers. With that said I just bought another one like came out of my car from OEM Surplus. I don't know a gov lok from a trac lok.
Old 04-07-2013, 08:27 PM
The Trac Lock was used in the 2nd gen F body. The 3rd gen got the Auburn or the Governor Lock. The Auburn was used most, but some got the Gov Lock. No 3rd gen F bodies got the Trac Lock. The Trac Lock was also used in the Ford 8.8 and 7.5, but it wasn't a Ford only part. GM used it in the corporate 8.5 and in the '68 to '70 Olds O rear end before Ford ever used it in anything.
The Following User Says Thank You to big gear head For This Useful Post:
Crosley (04-08-2013)
Old 04-08-2013, 08:18 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
rpo, trac lock
Trans & Rear end RPO Codes jamesnorris Transmission - Rearend 4 04-24-2009 08:00 PM
RPO codes runn141 Transmission - Rearend 2 11-22-2007 10:09 AM
Great Site for RPO Codes oldster General Rodding Tech 1 10-19-2006 08:09 PM
s10 rear end rpo codes S10lady36 Transmission - Rearend 2 10-14-2003 08:20 AM
1971 Chevy P/U RPO Codes CheyenneSuper General Rodding Tech 5 05-12-2003 05:23 AM
