gm rear disc - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-24-2008, 08:56 AM
racer rick's Avatar
gm rear disc
i have an 84 trans am .my problem is with the brake pedal hieght.when i apply the brakes the pedal almost goes to the floor.ihave changed the calipers due to leaking piston seal and bled the system.after this was done the pedal was engaging to low .i also changedthe pads and rotors at the same time.after checking the ebrake cables found that the ebrake does not hold either.how hard is it to rebuild these calipers with the internalebrake system. .
Old 02-24-2008, 09:00 AM
racer rick's Avatar
i have had a similar car with drum that worked fine.so if this problem is not fixable i am going to swap out diffs.
Old 02-24-2008, 09:45 AM
Frisco's Avatar
Glad To Be Here
Here is an article on how to adjust correctly.
Old 02-24-2008, 03:45 PM
You should be able to buy complete rebuilt calipers. That makes a lot more sense than rebuilding them yourself unless yours are in very good condition and just need new seals.
Old 02-24-2008, 04:47 PM
T-bucket23's Avatar
Wiki Edits: 26
Which calipers did you replace. If they are new why would you want to rebuild them. Are you sure you put the calipers on the correct sides so the bleeder is at the top. This is a common issue and an easy mistake to make. The E Brakes on those are difficult to get adjusted properly. The above referenced article should help.
68 firebird rear disc brakes TORI1 Suspension - Brakes - Steering 3 01-15-2009 10:37 AM
1971 Nova rear drum to disc conversion. 1971 Nova Suspension - Brakes - Steering 5 12-12-2006 04:07 PM
gm 12bolt rear interchange Walker Transmission - Rearend 5 01-21-2004 03:01 AM
Ford Ranger 8.8" Rear Disc Brakes nightrain_rod Transmission - Rearend 1 06-23-2003 06:48 PM
gm truck rear end rhett Transmission - Rearend 6 06-18-2003 05:11 PM
