GM rear end Idenification ?????? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-14-2009, 01:28 PM
Last journal entry: 1952 Chevy Street Rod Truck Build
I have a problem with a rear end I bought to put under my 1952 chevy truck I'm building. I was told it can out of a1980 Camero and bought rear brake wheel cylinders for it and it will not bolt up. It hits the ears at the rubbers on the end. The old one was missing all the brake parts. I've found all the numbers on the rear end put cannot locate my numb ers in any sites I have visited. Maybe some one can help. Here are all the numbers. On passenger side of axle--PS G61052....... on right side housing,,,D76 and underneath.... N 1249518 B. What is this animal?????? Thanks.
Old 03-14-2009, 01:29 PM
I have a problem with a rear end I bought to put under my 1952 chevy truck I'm building. I was told it came out of a1980 Camero and I bought rear brake wheel cylinders for it and it will not bolt up. It hits the ears at the rubbers on the end. The old one was missing all the brake parts. I've found all the numbers on the rear end put cannot locate my numbers on any sites I have visited. Maybe some one can help. Here are all the numbers. On passenger side of axle--PS G61052....... on right side housing,,,D76 and underneath.... N 1249518 B. What is this animal?????? Thanks.
Old 03-14-2009, 02:00 PM
Big Don's Avatar
rear end ID
Question: Are the lug studs ASE American thread or are they the Metric thread. Axle numbers do not mean much to me. However , if the rear end is out of a car in the late seventies or eighties then the rear wheel cyl. will be held in with those gosh darn stinking snap in clips ugh! I hate those darn things. If the wheel cyl are held in with the traditional two small bolts then the rear end is off of an earlier model. Does the rear end cover have a tag on it? Usually GM didn't use one except on posi units.
Old 03-14-2009, 02:04 PM
Post a photo of the rear, it is a leaf spring housing right?
Are you using new springs on that truck? If you aren't you will need to drill a new hole in the spring pad on the rear as the thru bolt is too far forward on the stock springs.
Old 03-14-2009, 02:25 PM
fast68's Avatar
likes chevy trucks & boobies
howdy there,
D76 looks like april 7 1976 date to me
got any pics ?
is it leaf type?
coil type?
7.5"
8.5"?
these casting codes are not really any help and never are any help
same diff housing casting was used on millions of applications
Old 03-14-2009, 06:17 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
I show a 2.41 posi from about '78 Camaro. 10 bolt corporate.
Old 03-15-2009, 06:18 AM
Rear end ID
Thanks to Big Don for your help. Wheel cylinder is held on by ase bolts but will not bolt up tight to holding area, it lacks about 3/16 " touching tight.
Old 03-15-2009, 06:24 AM
Rear end ID
Thanks fast 68 for your reply. The D76 is what I found too. Thats what I bought the wheel cylinders for that want bolt up tight to the mounting area, it lacks about 3/16 of an inch because the outer edge of the cylinder touches the ears on both sides which keeps it from mating up tight. It's a 8.5.
Leaf springs.
Gm 12 bolt truck rear end vs. car rear end '54 Pontiac Transmission - Rearend 6 02-05-2009 05:17 PM
4x4 12 bolt rear end same as 2wd rear end??? Ed ke6bnl Transmission - Rearend 2 05-24-2008 02:25 PM
Narrowing a 9" ford rear end powerrodsmike Suspension - Brakes - Steering 6 05-05-2007 12:53 PM
ford rear end indentifer 40blackie Transmission - Rearend 15 01-23-2006 07:39 PM
What is the gear ratio for a GM rear end? jpd37 Transmission - Rearend 6 02-23-2004 12:52 PM
