GM Relay Wiring - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-07-2010, 07:56 AM
octanejunkie's Avatar
Registered Looser
Last journal entry: Background: why I am here
GM Relay Wiring
Found a nice set of OEM relays on a Blazer in the junkyard, I think these will look good and add a factory flair to my build, question is how to wire them...
There are three relays on a bracket, relays are numbered as follows:
10039961, 10034222 & 10034222
I googled those numbers and found a listing for replacement relays referring to them as:
10039961 - Compressor cut-out
10034222 - A/C control
I also found pin-outs for them here, but sadly, I cannot really understand what the terminals mean, need to know where Input, BAT, Output are and whether they are NO or NC - I guess I can test this but thought I'd ask if anyone knew...
I would like to use them like standard Bosch relays for some basic, ignition/switch controlled high current relay applications like sending battery power to my coil, fog lights, trans cooler, etc.
Old 11-07-2010, 08:45 AM
T-bucket23's Avatar
Wiki Edits: 26
Ok lets use the first picture and assume you are wiring a fan or fuel pump.
Pin 1 would be the fused battery feed to the relay.
Pin 2 would be the feed to the fan or fuel pump or other load when the relay
was not energized. In automotive applications this is rarely used.
Pin 3 Would be the feed to the fan or fuel pump or other load when the relay
is energized. This is the most common usage
Pin 4 Would be the connection to your switch to activate the relay
Pin 5 would be grounded.
Your relay will not be number 1-5. There is a standard for relay terminal numbers.
Your pin 1 would be pin 30 Power feed
Your pin 2 would be pin 87a Normally open
Your pin 3 would be pin 87 Normally closed
your pin 4 would be pin 85 Activation feed
Your pin 5 would be pin 86 Ground
There are several threads on here on relay wiring. Most relays hav a small schematic printed on the case
The 30 87a etc is a standard that most automotive relays follow.
Hope this helped and didnt confuse you more
Chet
Old 11-07-2010, 09:54 AM
Registered Looser
Makes perfect sense, thanks Chet
Old 11-10-2010, 05:38 AM
Registered Looser
Going through some other materials, and looking at another SPDT relay I have, it looks like the terminal indications are different. I found this pic posted at summit
Which would make:
30 Power feed
86 Activation feed
87 Normally open
87a Normally closed
85 Ground
Knowing this, how do I map the pins on these GM relays numbered 1-5?
Old 11-10-2010, 06:33 AM
T-bucket23's Avatar
Wiki Edits: 26
Which would make:
30 Power feed
86 Activation feed
87 Normally open
87a Normally closed
85 Ground
I posted this above
Chet
Old 11-10-2010, 06:34 AM
the 9961 is a SPST relay NC (normally closed) contacts,
the 4222 is a SPST relay NO (normally open) contacts.
so on both relays:
pin 1 ... term 86 (positive side coil voltage),
pin 3 ... term 85 (negative side coil voltage),
must be wired with pin 1 as positive due to diode across coil, otherwise short circuit results (not a good thing),
pin 2 ... term 30 (positive supply voltage).
next is where the terminals vary
pin 5 (9961 relay) ... term 87a (load to be switched off)
pin 5 (4222 relay) ... term 87 (load to be switched on)
use the 9961 to disconnect a circuit when the coil is powered
use the 4222 to connect a circuit when the the coil is powered
Old 11-10-2010, 07:00 AM
T-bucket23's Avatar
Wiki Edits: 26
Which would make:
30 Power feed
86 Activation feed
87 Normally open
87a Normally closed
85 Ground
I posted this above
Chet
Old 11-10-2010, 12:37 PM
ogre's Avatar
the 'Duracell Project'
post a pic of the panel
you might be better off with a couple of bosch type relays than adapting the whole panel
Old 11-13-2010, 10:43 AM
Registered Looser
so on both relays:
Seems I have no immediate need for a 9961 relay, here is a pic of the relay cluster
Old 11-13-2010, 12:29 PM
ogre's Avatar
toss em.
all 3 are nc relays with no option to add a no circuit
just buy some nice bosch style relays
Old 11-25-2010, 02:11 AM
keep measuring the terminals in pairs with your ohm meter, when you find a pair that show a resistance greater then zero.. problaby somewhere around 300 ohms, you've found the two wires for the coil.
when you find the pair that show a dead short, you've got the normally-closed contacts.
now put 12v on the two coil wires, and you should get a click.. now figure out which pair give you the dead short with the coil energized, there are your normally-open contacts. no schematics needed.
Electrical Wiring kristkustoms General Rodding Tech 16 12-27-2010 11:00 AM
GM ignition wiring fivewindowcoupe Electrical 2 01-21-2009 12:29 PM
GM 3-wire alternator wiring 350cruiser Electrical 3 12-28-2008 11:57 PM
relay wiring issue Blob Electrical 8 08-01-2006 09:30 PM
Gm Wiring Diagram First Post Here lonewolf5347 Electrical 1 11-04-2004 03:14 PM
