GM right front disc clunks when apply - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-16-2006, 12:22 PM
I have a 35 Ford with Heidt Mustang II front and mid 70's GM front disc. Often when I apply the brakes I hear a clunk in right front. I ran this setup before makeover and didn't have problem. Any ideas
Old 08-16-2006, 01:03 PM
johnsongrass1's Avatar
Race it, Don't rice it!
Rubber bushing gone or missing on the pins. Brake pads moving around. Bad ball joint or wheel bearing...........
STUPID is as STUPID does...
Pull the calipers and check the slider bushings. There are small o-rings that the bushings run in and these o-rings commonly wear out. An o-ring kit can be had at your local parts emporium for a few dinero...
Mark
Old 08-17-2006, 01:05 AM
If the ears on the outboard pads are not tightened down properly it can cause a clunk.
Old 08-17-2006, 07:07 AM
Thanks all. How do you tighten the ears on the outboard pads. It looks like the ears slide on the caliper.
Old 08-18-2006, 01:57 AM
Squeeze them down with Channel-lock pliers until the clearance from ear to caliper body is as close as you can get it. Spec is .005", I think, but I've never been able to get them quite that tight.
Old 08-18-2006, 08:15 AM
I'm confused. I'm using 70's GM mid size car calipers and pads. The ears that slide on the caliper are 1/8" steel Ain't no bending them down. Could they be too close to the caliper and hanging up when I hit the brakes? The pads are pretty fixed the way they go on the caliper piston. I think I'll check the 0 rings and to see if the pads slide easily on the caliper
Old 08-18-2006, 08:27 AM
I have had this problem in the past and it was because a bracket mounting bolt had loosened. Lock tite took care of the problem. Check all your bracket bolts as well as the caliper retainer bolts.
Trees
Old 08-18-2006, 08:32 AM
Thanks. I'm going to give everything the once over.
Old 08-18-2006, 07:25 PM
they are about 1/8" thick but only about 1//4" wide. They are very easy to squeeze with a set of channel lock pliers. You need to squeeze them down. You aren't done with the brake job till you do.
Old 08-19-2006, 11:00 PM
I did mine a couple of times before I heard anything about the ears needing to be bent. They worked fine, but they were noisy when you used them. As far as I can remember, it might have made more of a clacking noise than a clunk, but my memory is sometimes fuzzy.
I'm talking about the ones in figure 17, near the bottom of this article: http://ucx.com/documents/brakenoise....%20outboard%22
GM drum to disc swap dundirtcheap Suspension - Brakes - Steering 5 07-30-2012 08:40 AM
Dent Repair Randy Ferguson Body - Exterior 25 11-26-2005 09:00 PM
Front Disc Brake Conversion for 1960 Studebaker JJFlashesq Suspension - Brakes - Steering 2 08-19-2002 05:50 PM
front disc brake wheel cylinder??--bleeders Tom34ford Suspension - Brakes - Steering 2 06-03-2002 04:02 PM
Front Disc Brakes 35 Ford Rancher Suspension - Brakes - Steering 2 05-24-2002 06:18 PM
