Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - gm rocket block
Thread: gm rocket block
  #50 (permalink)
Old 01-04-2013, 02:37 AM
Project89's Avatar
Project89 Project89 is offline
i figured i would update this i ended up buying a tall deck iron eagle block , with the bbc cam tunnel,
i did purchase 4 inch stroke crank but was able to sent it back in for the 3.875 stroke crank.im going with the 427ci build instead 3.875 x 4.185 with a 6 inch rod
i havent decided on a piston yet as i can get the afr 245s with a 70 or 80cc chamber and im waiting to hear back from some ppl running the 245 heads with the different chambers to see if i should get the 70 or 80's
other then that i need to come up with a cam and then ill be able to start assembling it
im going to run a pair of 70 or 76mm turbos on this engine should be able to make 1400/1,500 hp pretty damn easily
